97-stroker
- Joined
- May 18, 2011
- Messages
- 35
- Reaction score
- 0
We have a whole donor truck for anyone looking to swap there e40d to a zf-5 speed.
Donor is a 1995 F250 Powerstroke 4x4
$1300
Transmission - 150k
Transfer case
Pedal box
Clutch
flywheel
slave cylinder
master cylinder
crossmember
If you cant figure out the automatic wiring we have the manual PCM and wiring harness also.
Located in Cincinnati Ohio.
I will try to check this every night after work.
Thanks
Steven
If your truck is 2wd i have a donor 95 2wd truck also. Just PM me.
Both trucks are part outs so if you need anything else let me know.
$1300
Transmission - 150k
Transfer case
Pedal box
Clutch
flywheel
slave cylinder
master cylinder
crossmember
Thanks
Steven
