CoastalF350
- Joined
- Aug 21, 2013
- Messages
- 319
- Reaction score
- 0
Im reading over 400 kpa or 60psi at idle. I think this is too high giving that im running a 4in dp to a 5in exhaust. Any input?
I have the same issue with the livewire TS... As far as I know it will not read the ebp, ICPv, and a couple of other things...
I am and will continue to be disapointed with my livewire.
To verify go out and see what it says with the Key on Engine off... it will probably read 50-60psi... and at WOT you will probably see 160-170. I have talked with them multiple times about this. They claim they have never seen or heard of the problem before. Good luck!
