Exhaust manifold bolts
TD-5
British Columbia Canada
Just wondering what those that have suffered thru the misery of fighting exhaust manifold bolts more than once like to use?
I have found a few options, Factory OEM, which here in Canada have the dealer Gold plated Pricing,
ARP offers stainless studs, bolts or chrome moly bolts all at 180000 psi UTS & Bulletproof Diesel even offers a Titanium bolt package. These all seem reasonably priced.
I can imagine if any of these were to break or gall up they would be real bitch to get out.
TD-5
Hmmm, the above sounds like a rambling fool suffering from lack of sleep:blah:.....That would be me!:(
I'll try again;
What do you like to use to bolt up the exhaust manifolds on these engines?
i just used the stock 6.0 hardware when i did my 6.0 manifold swap. i have had them off once since then as well with no issues.
3brorce
Just need the spacers and bolts correct? Did you gasket match as well?
Dzchey21
wyoming
i run stock 6.0 hardware on my 6.0 manifolds. Pretty spendy i know but they do work well.
RCD has done some testing on thier manifolds and they use ARP with good luck. I know of several trucks that have had the hardware back off with stock stuff, not sure why
3brorce
How spendy for stock 6.0 hardware we talking?
3brorce
i wanna say it was over 50 bucks from the dealer, maybe even higher
Well shoot. That gaskets, spacers and bolts? Not to hi-jack, but to shim the fuel bowl for the dent removed on mani, how are you shimming it? Just washers or 6.0 rocker arm spacers?
HOOV3R
Central PA
Manifold bolts & spacers - 3C3Z-9S425-AA & 3C3Z-9A461-AA
Exhaust Manifold Gaskets - 6C3Z-9448-A
TD-5
I went with 6.0 OEM bolts & spacers. I actually ordered all my OEM requirements thru Sunrise Ford's on line store below in the vendor section. Great pricing & the extra 10% black Friday Discount covered the difference in my lousy CDN dollar. Thanks Jim.
For Reference:
Motorcraft # 3C3Z9S425AA Bolts are M8-1.25 X 40mm long
Motorcraft # 3C3Z9A461AA Spacer
