036speed
It is a Borg Warner 1356 transfer case (t-case) pulled from a 1988 F-350. It was an automatic gaser, but this case should bolt up to all 1987-1997 Ford 8-lug models. This case has 125k on it and spins freely by hand. you can also shift it easily by hand. It also has the PTO plate. This case is great for you guys that have swapped in a D60 in your F-250. Note, you will need to modify your front drive shaft to use this case if your truck has a TTB front axle / suspension system.
Case comes with the 2" long shift linkage bar that is not pictured on the case. I need the rest of the 4x4 shifter for my project.
$160. Located in Lodi Ohio. 45 min south of Cleveland Ohio.
Will trade for front leafs for a diesel F350
Thanks
Thanks
