Factory Front Spring Rates and Lowering
zporta
This is what I found when I typed in the part no. on my truck
Mine came with the 6k
• 4000lb. 5C34-5310-AHC
• 4400lb. 5C34-5310-AGC
• 4800lb. 5C34-5310-AFC
• 5200lb. 5C34-5310-AEC
• 5600lb. 5C34-5310-ADC
• 6000lb. 5C34-5310-ACC
MorganM
SE Houston
Coil Spring Specialties made a pair of springs for me with the stock rate, but 3" lower. Was in the bumpstops too often, and I'm using very thin bumpstops.
I would think while the 4000# spring would look great- it would ride horribly.
South Florida
Whats on your truck now Morgan? Height looks great. Any driveshaft hitting the floor problems? I really want to lower 1" or maybe slightly more. Plan to run a 22x12 and 305/40/22 Tire.
zporta
Maybe find someone that has the smaller lb spring and we can do a measurement comparison.
MorganM
SE Houston
Thanks, I've not had any clearance problems. Well aside from the frame interference. In the back I have DJM shackles with the factory block deleted. Shortened bilsteins too. Scott at Deaver helped source the parts.
I'm running 305/55 Wildpeaks on platinum wheels.
I'm using a second set of coils I had made that are 15% stiffer and .5" taller than the first pair. I seldom hit the stops, but it does ride stiff.
To do it again, I probably wouldn't go past 1.5"...maybe 2" max. Try to balance ride height with ride comfort.
South Florida
Looks like my truck has the AEC springs in it. 5200lb.
Anyone have input on what I can put in it to lower it an inch and ride good? I plan to change shocks too.
Trevor008
Maryland
I know Morgan at Midwest had or has 4400lb springs on his 15. He might have the info you're looking for
