Fast full parts for OBS
Cratos
ocala fl, area
I sold the truck before I got around to installing these. modded fill necks and 3/4 inch roll over valves 200.00 + the ride for th set (front and rear tank)
SPless
Elberton, GA
Its filler necks so you dont have to baby the pump to fill it up
Sent from my DROID BIONIC using Tapatalk 2
jschildm
Southeast Iowa
Filler necks and larger roll over valve (vent) so you can fill in less than a day and a half. I believe the 3/4" roll over valves are now no longer available/very hard to find.
Cratos
ocala fl, area
150.00 + the ride so send your zip code. and I'll send you a total and my paypal.
the fittings for the 3/4 hose are welded in and the lower baffles are removed and the rol lovers are 3/4 inch .and some 3/4 fuel hose .it lets you fillup faster not just on the first click of the nozzle.there are wight-up os most of the fourms.
Strokersace
Towanda, KS
Do they leak at all where the bungs are welded into the neck? The 1st set I did leaked there because of the seam/pinch weld that I compromised when drilled and installing the fitting.
jschildm
Southeast Iowa
Got the quick fill stuff yesterday. Thanks a lot. Hopefully get them on next week and impress the wife next time we stop and fill up.
Strokersace
Towanda, KS
F-Superduty of similar vintage (OBS) I believe. They seem to be difficult to find though.
You can't find them new anymore. They can only be found in junkyards now. I tried to get some about 2 years ago. My ford parts guy found 6 new ones in the entire country. When we went to place the order, 2 had been sold and the other 4 were in the system but unavailable.
