Feel free to chime in
whtdmax
As some of you are aware of my last post with the spacer I found under my rocker arm, I have since replaced all the rockers(passenger side only for now), bridges and pushrods. I still have the thumping noise but, only louder. I am in the process of uploading a video. It also gave a cel of cyl misfire. This is also a first
whtdmax
Well, I took the valve cover off and started it up. The front valves on the passenger side (I'm assuming to be intake) valves are barely opening. Can someone chime in and correct me if I'm Erin but, that's a lifter or cam correct?
