FICM
qcfarmer
I have a bone stock 03 excursion that the ficm just went out on. I was wondering if there are any benefits to running a modded ficm compared to a stock ficm on a stock truck. Thank you
Jarrod B
Corpus Christi Texas
Tuning wise, it will help on the start up and go and see that up to 1500 rpms ish.
as for the 48/53/58 volt. not much gain. 48v is good enough.
qcfarmer
Just want to confirm its the ficm. KOEO I have 48v when I start it it drops to 28v and truck runs rough.
strokin6L
Springville NY
yup FICM is bad. You can have a FICM that'll read 48v with KOEO, startup and idle....and it'll still be bad, even though it reads 48v. For some reason the FICM's half shell will go bad, but still read normal. Had seen a few trucks like this and ford replaced just the half shell and then all was good.
Derek@Vision Diesel
Canby, OR
Would also agree the voltage is not always the answer. But if it shows low, it DEFINITELY is bad.
Would suggest something other than a Ford unit though. Give us a call if you need any thing, we have them in stock.
qcfarmer
Update: installed ficm from a running truck and still have the same problem. The truck starts and runs fine when cold and as it warms up it starts to idle rough and lose power to the point that it will stall and barley start and then stall right away. I haven't had a chance to volt test the ficm but it did come out if a running truck. What else could it be? HPOP related? Injectors? My brother has an Insight to monitor his truck maybe we should hook it up to the Ex?
qcfarmer
Filters have been a while (7-8 months ago). I will try to get the insight hooked tonight or tomorrow.
qcfarmer
Ficm from friends truck maintains 48v. Truck still runs rough and loses power until it stalls out.
Dave
For sure the ficm
Sent from my Milestone X2 using Tapatalk 2
When FICM voltage is this low always always always individually load test the batteries and have the charging system tested.
If the batts are more than 4 years old. Replace em regardless of what a load tester says
qcfarmer
Update 2: took it to ford and they said its an injector (number 2) that stays open allowing compression to enter the fuel passage which starves the other injectors of fuel. He said he has seen it before. He suggests I change the injector and the one beside it and that should fix it. My question is should I do all 8 (truck has 420 000 kms) or just the two?
