Finished intake manifold. Dyno tests next.
SLOSIXOH
Finally finished my modified intake manifold. This is my take on modifying the stock manifold. I tried two different designs.
The first one I tried was an "economy" version I was thinking about. I just bored down from the top to remove the columns. What I found was that it would leave a lot of a couple of the columns still intact inside the intake. I did not want to make the hole any larger for fear of cutting into the sides of the manifold. Idea #1 scraped.
Idea #2 was to remove the top of both sides of the intake. I then bored the columns down and counter bored the bolt holes so the attaching bolts would sit below the floor of the intake. I also removed all casting inside the manifold for the EGR valve. I found several obstructions still left from the machining of the columns that needed to be removed. On the side with the alternator bracket I found the side walls had some obstructions that needed to be removed. I welded extra material on the outside of the intake and then ground out the obstructions on the inside. I decided that I wanted to keep the radius ports on the floor of the intake. I for one think they act as a velocity stack. I then welded up the hole from removing the EGR. Then welded on new tops to both sides of the intake.
My idea on how to access the attachment bolts was to make an access hole in the top over each hole and the seal those with a pipe plug. I added extra material around each hole to allow a few extra threads after tapping the holes. Checking the inside of the intake after installing the pipe plugs shows they sit flush with the roof of the manifold.
I hope to test this manifold in the next two weeks. I am going to do a before and after dyno test with the manifold to see what it does. I changed the intake on my shop/test truck a couple of weeks ago. It has a 05 style intake that I had cleaned before I installed it. During the intake swap I installed an EGR delete kit from RCD. My plan is to do a couple of runs with each intake. I will also test the stock air filter vs. air intake kit debate. I have a AFE intake kit to this test with.
SLOSIXOH
Finished manifold.
Redneck6.0L
Nice work, there's a few guys here building them much the same. Any of these modded intakes work great.
windrunner408
Looks good. Have you pressure tested it yet to verify that it holds pressure and doesn't leak??
TheReelMuhcoy
New Jersey
I have not read up on these modified intakes, so I am not 100% sure what I am looking at so correct me if I am wrong....
Am I seeing that the bolts are now internal of the manifold and those Alan plugs are just that, plugs?
I have been considering the idea of doing my own intake mods down the road but haven't done the homework yet. Looks relatively easy.
windrunner408
Yes you are correct Jon. Those plugs are just that. IMO modding the intake isn't hard persay but there are nuances like with everything else that you have to take into consideration.
Pizza pig
MD
wait, youre just using pipe male pipe thread plugs? Thats probably not a good idea for leaks. You should have used o-ring boss inserts and plugs. But Im sure if you thread seal them they will be just fine.
cfdeng7
CT
I agree greg. Orb plugs are better suited to this application than npt plugs. However nice work on the manifold man came out really nice. interested to see how it does on the dyno
SLOSIXOH
I tested for leaks with water. I still need to make a jig to seal off all openings and apply pressure. This is my first manifold and more of a test to see if it even makes power improvements. During the build of this manifold I found several things that I would do different and plan to change some things if this manifold works. I know there is a lot of discussion on modified manifolds and I want to see results. I do believe that they make an improvement, I just don't want to spend $800-1200 for what people have described as "It feels like it makes an improvement". If I just spent $1200 I would think it worked too, even if it didn't.
I really don't see a problem with NPT pipe plugs. Yes I will use sealant on them. NPT plugs are cheap and I already have NPT taps in my toolbox. Less money for me to spend on an experiment.
My goal is to see what percentage of an improvement it can produce. Stock and tuned numbers. Stock air filter and aftermarket filter numbers. Will it make 10%, 15%, or 2%?
STR8LINE
Barren River Lake, KY
If you see a significant difference Iam going too Try this on mine! Iam excited too see results here man, Kudos too you!!! an like ODAWG said, Thanks for postin this up!
range91
michigan
where are you rerouting the coolant to that run through the intake? Is that a 04 intake any draw back to these compared to 05-07's
SLOSIXOH
I plan on running the coolant from the oil cooler to the degas bottle. It will no longer go through the manifold. I plan to monitor the EOT to see if it causes any problems with the oil cooler's coolant flow. The bottom of the intake is welded shut where the coolant returned to the engine.
I have not cut open enough intakes to say one model is better than another inside. The only difference I can see from the outside is the casting around the EGR is different. I have a couple of 03 intakes that I will try also. I plan on removing the rear cross over and welding up the holes that creates.
TheReelMuhcoy
New Jersey
Has anyone tried this with a 6.4 manifold? Just thinking down the road if I do plan on porting a manifold it will likely have to be a 6.4 manifold.
SLOSIXOH
I believe there are a couple of people that have done the same to the 6.4L intakes too.
lenzhotrod
I'm doing an 03 and plan on keeping the rear crossover for 2 reasons. First I think it will help the manifold not warp as easy when welded and it serves as a balance tube. After all is welded up I may cut it out, but will still install at least a 3/8 balance tube.
