First time 4X4 use a little bit glitchy
8WR_ZJ
Are the hubs still vacuum operated?
8WR_ZJ
If you manually lock the hubs does it still do this? Were the front shafts spinning while this glitchy behavior was happening?
Sportchassis06
I don't think the driver could tell,unless he was under the truck??while driving it?
8WR_ZJ
Yes i always had to have another set of eyes other then my crawler i could just look out the window. Full width axles in a grand cherokee...
EpicCowlick
Yeah, there was no way to tell from the driver's seat except it was obvious the front wheels were not spinning. And no, the hubs were set in Auto. I'm pretty sure if I turned the hubs to LOCK the front wheels would have been fully engaged. Missed opportunity. It righted itself by the third try and has worked fine all winter.
EpicCowlick
Something like that but it was almost definitely the hubs failing to engage. The 4Hi and 4Lo indicators come on the dash only when the transfer case has completed the shift and those lights were on.
Jomax
Arizona
My truck has been perfect since new. It's odd it does it like this.
its on the fly 4x4... should lock better going faster then a crawl.. once 4high engages then stop and do the normal 4lo shift..
I've gotten the shift delayed, please pull forward message before. Real handy when you're in a tough situation.
it us because it is on the fly.. as in it is suposed to be while still moving forward while not spinning the rear tires.. BEFORE you get in that scetchy situation...
UpstateDieselGuy
Mayfield, NY
Yeah, I know, but sometimes you don't know you need it until you're in the danger zone lol
I guess I miss the old manual lockouts and shifter, you know what you have all the time!
