Flo Pro 5" vs Mbrp 5" Thoughts and Opinions
Dalton_H
Hey guys just wanted to get your take on these two systems on a 6.0. Ive had 4" mbrp systems on 6.0s and they always fit perfect and ive had a 5" flo pro on a 7.3 that didnt fit well at all especially with the gooseneck. We installed a 5" mbrp in my buddys dmax with a gooseneck and it fit perfect so just wondering if anyones had any issues putting either system on their 6.0 with a gooseneck. Btw my truck has the type of gooseneck where the ball folds down. I know these type of threads are out there but have looked and looked and have not found anything about the flo pro on a 6.0. Ton of 6.4 threads but none for a 6.0 for some reason. Trying to get one ordered today so any help would be greatly appreciated along with pics!
Dalton_H
Also the exit on the 6.4 flo pros seems to be different then it was on my last 7.3 so id like to see the exit on a 6.0, Dont know why flo pro would make it different but who knows.
This is a 5" flo pro on a 6.4 with 6" mbrp tip. Id like this exact set up if the 6.0 flo pro exits like this and will fit with my gooseneck.
Dalton_H
Ok perfect, i had a suspiscion that the flo pro would just exit straight out the corner with no bend in the last pipe section but just wanted to make sure. Thats exactly how it looked on my 7.3, i dont understand why they put that extra bend in the 6.4 tail pipe section but i wish they did the 6.0 the same way.
Dalton_H
It's a 6.4 but, it exits the same, FLOPRO 5"
See the 6.0 tail pipe section isnt bent like the 6.4 for some reason, if it exited like yours id buy a flo pro but i dont think im sold on the way it exits for a 6.0 like the truck above yours.
6.0 p-stroke
North of San Antonio, Tx
I run 4" flo pro duals on my 6.0, when I installed it in 4-5 years ago it was a pain in the ass. The biggest problem I had we hitting my gooseneck hitch, it's a B&W so it takes up more room below the bed which caused the exhaust to hit it and screwed up the way the tail pipes exited. I spent a lot of time modifying it to get it to look right. However when I installed a 4" flo pro single kit on the 6.4 it fit perfect, but it doesn't have the same hitch that's in my 6.0.
Dalton_H
Got the 5" mbrp on that i ordered from Eric, fit and finish imo were far better then the 5" flo pro i put on the last truck.
dieselpower
Best Coast
neither. just get a diamond eye. waaay cheaper and you can't really get a low quality exhaust unless it like literally has holes in it or something
Pikesnogle
Ashburn, VA
MBRP hands down. I had one on my Ranger, made a nice rumble for a 4 liter.
Buddy of mine has the MBRP duals on his Cummins Dodge, sounds unreal. I've been watching youtube videos of MBRP exhaust systems on trucks ever since I bought my 250 dreaming of the MBRP duals.
SEABEE08FX4
Montgomery TX
They are cheaper ( and there is a reason ) but I have put several of them on and they never fit right with out tweaking them or a lot of adjustment. The MBRP is a lot better fit and finish. Also Diamond Eye is notorious for including the wrong clamps, as in you order a 5" kit and it shows up with 4" clamps or vice verse.
'94IDITurbo7.3
Fowlerville, MI
OP, do you have any pics of the exit of the MBRP you put on?
TooMuch03, how did the install of that Flo Pro go? fitment issues?
