Fluid mist from cylinder on compression stroke
95powersmoker
Pasco, WA
Hey guys, I just bought a project truck that started blowing white/grey smoke while the previous owner was driving. I was able to start it up when i went to look at it and it was blowing lots of smoke and knocking on the #2 cylinder. Shop thought it was a head gasket... I noticed nothing wrong with the oil in the crankcase or coolant so I went ahead and bought it anyways. Now, today I go out and go to do a compression test and crank it over to eject any fluid in the cylinders. The #2 cylinder is pushing out a mist of fluid on it's compression stroke. I think it's coolant but it's difficult to identify because it is such a think mist but very noticeable. If it is coolant, it leads me to believe the head gasket has failed or possibly injector orings (I'm unsure if this could even be a possible problem)
What do you guys think? Anybody faced this? Could it be a cracked injector cup also? I'd hate to take the head off if it's as simple as pulling the injectors and replacing the orings and cups. I know 7.3's hardly ever have issues with head gaskets, this isn't my first 7.3 and surely not my last. I just wanted to see if anybody has had similar issues and gone through this. I am just looking for some educated information.
Thanks.
95powersmoker
Pasco, WA
Alright guys, well I did exactly what you said, pressurized the system and have nothing but oil in the cup (still draining cuz I didn't pull the galley plug) I keep wiping it out and have not seen coolant in the cup... Any other thoughts or ideas... Head gasket?
95powersmoker
Pasco, WA
Just for chits and gigs, with the advice of a good friend, swapped #2 and #4 injectors... The squirt followed the injector and is diesel... Must be an injector nozzle issue...
