Fog Lights/High Beams
Wildman
Looks sketchy.
The fog lights and headlamps are entirely controlled by the Body Control Module (BCM). The headlamp switch is merely a low current input to the module, which then determines which lamps to energize. Can't see hacking up a harness with this ebay special ending very well at all.
BIG JUICE
Valrico FLA
I'd like to know if anyone used this also?I've been looking for simple way like clipping wire or jumper like previous trucks, but the wiring schematic on the bcm looks like it switches polarity
jcain
I'd use diodes to protect the bcm and then tap the highbeams with a relay and diodes and power the fogs.
