Fox 2.0 shocks
White Stallion
Okay I'm lifted 5.5" in the front and 7" in the rear. I have the bilstein 5100s on it now but they are maxed out and need to get them replaced before I tear one of them up. I'm looking at the Fox 2.0s and found fronts 5.5-7 but rears are 4-6. Will the rears work with my current lift? I located this on eBay http://www.ebay.com/itm/261598011465. Is this a good price for a set of 4?
mikah215
Fox is a good shock and very easy to rebuild if needed I have mine with resys on them and yes they will work unless your really flexing the truck then you should be fine
03 f250 6in lift 20x14s on 37s 4in straight pipe sct street tune from innovative bulletproof ficm
powerlifter405
Butt Town
OBSWIZ can get you custom valved fox. I believe the carli vendor on PSN can do the same. I hear for DD the custom fox price wise can't be beat and they won't rust out like the 5100.
hit up smokinstroker on here, he will get you squared away with the fox stuff...
TheReelMuhcoy
New Jersey
Ironic, my buddy and PSA Member just picked up a set of 2.0 Fox shocks that he cant use on his truck. He's looking to move them quick, \I bet he will hook you up with a good price.
