Powerstroke Racer
How many of you have played with pinion angle?
I realize pinion angle is very important for a race vehicle but on a DD it doesn't ever seem to be a point of interest.
Let me tell ya, it should be a very important part of any truck with decent power, I lowered the back on Amanda's truck a few years back and had about 1/2 degree at normal drive height and always noticed a slight vibration when heavy on the throttle but not a big enough vibration to warrant looking into it at depth. Well fast forward, we buy a tongue pull toy hauler (7100lbs empty weight) and I immediately noticed the vibration was constant and power was lacking as compared to when I pull my race truck on the goose neck.
So checking it with the trailer attached netted a positive 2 degrees.
So today I changed it to 5 degrees negative and boy what a surprise, a whole different truck, you can feel a performance gain all the way around. Ideally you want 0 degrees for maximum efficiency but not possible with a leaf spring setup and high horsepower/torque, plans are to drop truck another 2 inches so I should end up with 3 degrees negative at a stand still when all is said and done.
