FS: AirDog 2 DF-165
PsRumors
Cartersville, GA
This AD was pulled from my truck today. It is just the pump, mounting brackets, and the plug with a pigtail. There are no hoses, fittings, filters or additional wiring harness. Just what you see below (plus the remainder of the bracket to mount to the frame).
It has been on my truck since Jan 2011 but has only about 10k miles on it. I did a custom e-fuel as seen here My e-fuel system Airdog II - PowerStrokeNation : Ford Powerstroke Diesel Forum. We are going to start traveling some and I wanted an easily available fuel pump just in case so I installed a SD pump in place of the AirDog.
Never had a problem with it and it has always held 65 psi, of course I only have stock injectors.
This is the DF-165 adjustable AirDog II with the adjustable regulator.
$300 or make me an offer. Not sure what its worth and would like to get it sold.
08BIGRIG
WI
I take it this was on your 97 Ford? What years does the pump all fit and work for?
PsRumors
Cartersville, GA
This was on my 97 but came out of the 99-03 7.3 kit. As it sits it can be used on any truck but it will be a custom install or AirDog may sell an install kit separately but I haven't checked.
You will not be able to buy this pump and just plug it in.
