wildstang3
So I drove my 02 f250 from Denver to Iowa last night and when I pulled into the driveway started smelling fuel and got out to check and found it spewing fuel on the passenger side so I popped the hood and found fuel in the radiator surge tank and it had pierced a hole in the surge tank which is where my leak was coming from. (had enough pressure that I had fuel down the entire passenger side of the truck, trailer and bronco I was hauling) Truck ran fine until I turned it off, I restarted the truck to uncouple the trailer and move the truck out of the way, then it was running rough and sounded like it had a fuel knock. I immediately shut it down. This morning I started it just to see if it had lost its fuel prime and it popped right off so I shut it off right away. I didn't notice any smoke or missing or any noticeable symptoms except my mileage was worse than usual. What do you think I'm looking at bad injector cups? Injectors? Any ideas would help as I'm stuck in Iowa now! Thanks Tyler
