fuel lines for second hpfp?
08BIGRIG
WI
Does anyone know what size the factory fuel lines are that connect from the fuel bowl to the hpfp? Also how would one tie in another line for a return line from a second pump into the fuel system? Would you be able to tee both the line coming out of the fuel bowl feeding the hpfp as well as the return line from the stock located hpfp back to the fuel bowl? Just trying to figure out how to pipe lines to a second hpfp. Both feed lines and return lines.
08BIGRIG
WI
Plans are to put a t in at the fuel bowl to feed the two hpfp's. And for the return line for the second hpfp run a line from the second hpfp to the line connected to the fuel cooler and t into it before the fuel cooler.
tensixniner
What tune do you normally run?
Have you ever put a gauge on the test port and monitored pressure while your driving?
08BIGRIG
WI
I run the hd300 for getting down and the mild 250 for DD.
I have never put gauges on it while driving. I do have a Air dog 165 on the low pressure side. Just seeing what people think about running this setup.
blk350on20s
I know jeremy did the same thing. All stock. You would have to call him though. I doubt hell come on here. Thats how the black truck that kills it pulling is setup. Might be something on youtube to. Lubeowner is his name for forums and youtube
bigrpowr
<How I Fly
Administrator
i think he got banned from every forum.
