fuel pressure drops
06f250powerstroke
ontario, canada
I have my fuel pressure set to 65psi and it never moves at 3/4 throttle but at WOT it will drop to 52 psi. Im running a FASS 95 and a RR kit, could this just be my pump not being big enough?
windrunner408
Yes it is a high pressure unit. I am inclined to think your pump is just not big enough but it's not bad as 52psi is just fine for your injectors. Do you have a sump?? I would try one of those if you dont. It may help remove some strain on the pump.
I have a sump with an AD150, feeding the stock pump, feeding a RR kit and my pressure drops from 64psi at idle to 50-52psi at WOT.
faster6.0
Turn the regulator on the RR down to 55 psi and see if it helps.
strokin6L
Springville NY
i installed a stand a lone FASS on my buddy's '05...think it was a 95/90 series pump. he's running stock injectors with no RR and fuel constantly stays at 62psi and never drops.
Strictly Diesel
Phoenix
Locate the return hose on the FASS (one going back to the fill neck) and clamp it shut (with something that won't damage it like hose clamp pliers). Drive the truck and see if it's any different. If it still drops pressure, the pump isn't moving enough volume. If it holds pressure with the return hose clamped shut, the spring and ball combo in the pump isn't strong enough. I know that FASS is recommending the use of an external fuel pressure regulator (one of theirs naturally) for higher pressure applications, both because it's adjustable and also because the pressure can be dialed up higher than their spring/ball combos.
doubledee715
I have an air dog 165 with 205cc injectors and my fuel psi drops to 40 psi at wot.
