Fuel pressure test..help needed
cutthroatxxx
So I need to check my fuel pressure but not sure what Im doing.I called around & found the pressure port adapter which the fella I was talking to said that a hose goes on the other end.So do I just hook the hose up to it?Id imagine I need to piece something together.Does anyone know of a write up or can tell me what I need to buy.Thanks
ghohouston
Lewisville,Texas
there are two 3/16 allen plugs in the bottom of the bowl. you need to remove one of them, and install the hose of the gauge. not sure if you need an adapter or what, its been a while since ive tested one
golfer
Justin@DP-Tuner
You can use either port (I use the top one). You will need a 1/8 npt to -4 male boss adapter like THIS ONE.
Most all electronic fuel pressure sensors available for these trucks have 1/8 npt threads.
