dzldoctor
- Joined
- May 25, 2011
- Messages
- 515
- Reaction score
- 0
i have a 2006 6.0 that has an in the cab gauge tapped into the factory test port. Pressure is at about 70 psi, and has the updated spring and new ford HCFM within the last 6 months. The issue is in the SLR tune at wot the pressure will drop to about 35 psi. In all other tunes the pressure will not fall below 60. installed the gauges at the same time as the tunes. is the factory pump not enough for the fuel demand for the tune or is there a problem?
