Fuel PSI not showing up on CTS
ford rules
So I got my fuel pressure guage hooked up in my test port on the fuel bowl and my edge EAS hooked up to my cts but the CTS just shows 0 psi when i select EAS 1 or 2 any ideas whats going on with it? I was thinking i need to reflash/update the cts maybe?
Any help is appreciated.
Superblazin
been a While since I hooked one up put pretty sure you have to set the gauge up with the computer first.
Thanks for the tip Matt! I had the same issues as the Op and had figured I had a junk sending unit.
I pulled the pod out this morning and did the updates ect.
Just got back inside and she works like a charm! Also since doing the update it now has a pid for ebp!!
Sweet
HOOV3R
Central PA
Sweet
EBP now? Guess I need to update mine.
To the op, set the sensor to a 0-100psi sensor using the software, and set its name.
ford rules
Yes just did mine a few hrs ago and it works great now, forgot to do the updates though ill have to pull it back out.
