fuel psi question~!~!~!
ncdzl
Theoretically it'll run on any positive pressure...
But as stated...the injectors and probably hfcm will die soon.
what a mess
rockford il
well thanks you for the responses fellas that what a was feared of I figured I will prolly get rdy to a set or injectors rebuilds
what a mess
rockford il
well 2 months after I installed my fuelab my fuel pressure dropped to 0 and I thought I gage took a crap but I found out later it wasnt my gauge =( heh
ncdzl
I'll assume you drove it very little to none at all after noticing this?
what a mess
rockford il
truck ran the same but it was wintertime and I don't drive like an ass on the street and I drive even less in the wintertime so with no wot runs or nothn it ran normal just dd it
ncdzl
Odds are you're ok at this point. Need to address the issue asap though.
jdc753
Norton, MA
When fuel pressure approaches single digits and lower you should experience lack of power and rough running along with a louder motor. Shouldn't have enough power to get out of its own way and get pretty violent running
But that is my experience from the couple times the filters gelled up and I limped the truck home
what a mess
rockford il
yea it it was odd it ran just fine and didn't run ruff at idle either it was very odd butt the fuel lab is at the booboo doctor and the stock pump is hooked back up
what a mess
rockford il
the second odd thing is that the fuel lab somehow was pushen fuel threw the wires push it all the way up to the relay inder the hood that burnt up and never shut the pump off so burnt the pump up heh
