Fuel psi sending unit location
Adamv7010
Where do you guys put the sender for incab fuel psi gauges?
I have a reg return so should I use the port on the regulator? I also Still have the upper bowl.
Spoolin'
Florida
Mdub707
Mohawk NY
Without a RR, read at the back of the heads. With a RR, at the regulator like suggested.
Adamv7010
That's what I was thinking. Just wanted to be sure. Is there any reason I can't use a low profile fitting and plumb over to a more open location to use the sender? I'm afraid with it straight up off the regulator it'll hit the hood
ford rules
You can do this if you want to pressure will be the same wherever you plumb it to.
