fuel PSI
obs7.3
Ohio
I have a Raptor fuel pump on my truck that just has a direct fuel hose up to the fuel bowl. I put a fuel PSI gauge on the pillar (electric one) and put the sending unit on the fuel bowl where that valve-stem was. with the pump pressure all the way down it reads 65-85psi at idle, the needle doesn't sit still it just bounces between those pressures and reads 95-100psi around 2k RPM.
I was thinking about putting in an xx-fuel filter & water seperator and a regulator on the truck soon...
where should the regulator go? brand to use? would it be better to just get an air dog 2 and get rid of the raptor? ect. any advise is appreciated.
thanks
Yodersstrokin96
Alvada, Ohio
you need to get or build your self a reg. return, and filters on the frame. Use an aero motive regulator and regulator usually goes up about your HPOP all the air dog will do is give you a pump filter and base. you would still need to make/buy a reg return
