fuel pump power supply ?s
mandkole
Northwest
Ok, the battery issue has been resolved (one was dying), but the fuel pump still no work at KOEO. Its not getting power either. The truck starts much better and still runs-- the pump does not come on with oil pressure either.
Interia or roll over switch failure? Can it happen? Someone please school me on the pump circuit for the 2000. In the meantime, a little interwebs surfing..
mandkole
Northwest
Fug... my test light was just acting up. The pump is getting plenty of power-- it had a good run the past 8 years.
Arisley
Arlington, Texas
Or. when your test light fails and tells you that 277VAC is not present, and you believe it. Painful lesson right there.
