madman1234509
Alright, im starting to piece together a low pressure fuel system set up. I just had a question about a regulator. Im going to use an aeromotive regulator. Instead of using a distribution block like elite has, can I just buy a regulator that has multiple ports on it? At this point really all I need is an inlet from the lift pump, an outlet to the injection pump, an inlet for the excess fuel from the injection pump and fuel rails, and the bypass out of the bottom and back to the tank.
Is there a reason everyone uses this distribution block instead of a regulator with multiple ports? Also can anyone post detailed pics of the block and show which lines go into and out of it and the regulator. Ive never really seen one up close.
