Fuel system question
Wemoy1
PA
I know this was on here before but I couldnt find it. I was wondering who has made there own fuel systems from there airdog 2 up to the HPFP with a fuel regulator and gauge. A budget kit I guess I should say.
blk350on20s
I have made my own with my fass. No regulator though. -8 line straight to the hpfp. -6 for return and bringing the 3 returns together with-6 nitrous Y's. Frame mounted cooler than to the tank
blk350on20s
Its plugged in but just zip tied to the loom. I will have it plumbed in in a few weeks when i install dual fuelers.
Wemoy1
PA
oh ok have you had any issuses with the truck do you have pics of your y setup?
08PowerSmoke
Raleigh NC
I did mine.....well this weekend I will finish it.....with a little help (thanks Madman)!!!
Aeromotive 4 port regulator....10an supply line to airdog....6an return....8an to the hpfp....looks like the elite kit just no block! Its a lot of parts and can be budget depending on how you order everything. Price varies with what you want push fittings are cheaper and so is just plain rubber hose. I have nylon braided and thread tightened fittings which is more expensive but looks awesome.
B585Ford
WV
How about some pics when you are done!!!
blk350on20s
Heres a few pics. Its pretty much all hidden so theres not much to see
And the frame mounted fuel cooler
09stroker
Texas
What's the safe fuel temp range? I run one of those in my fuel system and my tank and filters will still get pretty hot to the touch.
blk350on20s
It has been for me. Might throw another one in because of the twin pumps. I couldnt tell you safe range. I never monitored temps prior
08PowerSmoke
Raleigh NC
Will do on the pics.....I went the expensive way of course. Nylon braided hose....thread type fittings. Aeromotive everything I could! They even make a fitting that converts the stock HPFP hard line to a AN line.....So no tricks in getting to the HPFP! Just cut the stock line install the fitting and run flexable line around to the regulator. I can try and get a parts list together but like I said I went the crazy way and went for looks. You could really do it CHEAP if you had too.
Wemoy1
PA
ok thansk for the pics this is helping me decide on what to do with mine I like the budget idea and everything looks so clean.Were can you get the braided line like NAPA or summit
08PowerSmoke
Raleigh NC
THIS IS A START.....WWW.JEGS.COM
4 port Aeromotive regulator: 027-13224.... 183.99
10 feet of 10AN nylon braided hose: 555-110932 ... 69.99
6 feet of 6AN nylon braided hose: 555-110911 .... 39.99
6AN port plug for the regulator 027-15626 .... 9.99
10AN hose end fitting 555-105003 .... 10.99
6AN hose end fitting 555-105001.... 6.99
10AN fitting for regulator 027-15608 .. 13.99
6AN fitting for regulator 027-15606 ... 15.99
http://www.jegs.com/c/Fittings-Hose_Hard-Line-Fittings-Tube-Nuts-Sleeves/200706/10002/-1
08PowerSmoke
Raleigh NC
I will post a better list later my parts sheet is with my truck in the garage that should be enough to get you looking though.......they make fittings that are 10AN to 3/8" NPT for the airdog.....I put a guage on the side to measure fuel pressure too! Also look at banjo fittings for the fuel cooler and that one is 6AN also. You will also need a 6an to 8an adapter for the regulator on the HPFP side and the sensor will plug in also. I will get pics up ASAP!!!
B585Ford
WV
Thanks for the derailed parts list.
Wemoy1
PA
I was looking at you one pic of your engine and do you have to pull the lines off the front of the heads and run them down to the regulator or back to the airdog?
