fuel system
what a mess
rockford il
i have a fass pump not installled yet but im goin to be upgradeing my fuel system because i lose psi bad anymore so i also have a RR kit on truck alrdy so can i jsut cut the fuel bowl off and run a t from the feed lines to the fass pump not useing stock pump at all anymroe is my plan and will taht work jsut t ing the 2 feed lines or do i need to make them the same lenght? and will hte fass pump push enough to supply stock injectors or do i need a pusher pump also pls help thank you much
Pizza pig
MD
what fass is it? a standalone pump assuming? I would sell it and buy a fuelab or aeromotive pump and use a y block to feed the heads.
05wh250
hendersonville, nc
you should be able to look the model number up and it will tell you. but like pizza pig said a fuel lab or aeromotive if its a standalone if its a pucher you can feed a fuel lab or aeromotive with it.
what a mess
rockford il
not sure on how old it is and is there a y block big enough that i can use my fuel lines that are feeding the heads alrdy or do i have to get new fuel lines also?
what a mess
rockford il
ALRIGHT its a pusher pump fass 150 em1001 is what i found its not dark out alot easier to see heh so i will need a fuel lab or a1000 then correct? so i dont have to use stock fuel pump
