Fuel system?
vcassens
Godfrey,il
Who makes a complete fuel system I am wanting a sump in the tank and everything replaced that is factory. So I need a sump, fuel pump, filters and bases, and all the lines and fittings to get it to the motor and back to the tank. Thanks for any input
mcdaniel1991
Germany
I can post a list of the custom kit i was building?
Sump—---10an---—Ball Valve——10an------Baldwin FB1311 base with 175-2949 water separator——10an----A1000 marine Fuel pump--10an--Baldwin FB1311 base with 1R-0750 Filter—10an to 8an reducer----8an---Engine bay —8an pressure fitting--Y===== ===6an===Front of heads with 6AN to 12x1.5mm 90°
Back of heads with 6AN to 12x1.5mm 90°==6an===Regulator--——6an bulkhead fitting.
I think this was everything. Its a little cheeper if you get it all from summit but their site is a little difficult to use.
Jegs
Braded hose -
6’ 10an braided steel
6’ 8an braided steel
20’ 6an Braided steel
Fittings-
8-10an hose fittings555-100003
6- 10an ORB fitting555-100204
1- 10an-8an ORB fitting 555-110166
2-8an hose fittigs 555-100002
1-8an pressure fitting 555-100521
10-6an hose fittings 555-100001
1-8anY6an fitting 555-15165
8an hangers 023-FCM3485
1-6an bulkhead fitting 555-100560
2 6an hangers SUM-G1881
1- 6an 90 degree 555-100021
SInister FP Regulator $150
a1000 pump
Total $1100
Summit
4x Head fittings 949092ERL
Total $60
Ebay
2-Baldwin FB1311 base
1-175-2949 water separator or BF1252
1- 1R-0750 Filter or BF7633
$100
Obviously it might be a little different depending on which components you use.
JGman141
Ohio
I've got Marty's a1000 system and I love it, doesn't drop fuel pressure even at WOT. I would highly recommend his set up.
04stroker
Sarasota-Bradenton, Florida
I would use Marty's. comes complete. Yes you can piece it together yourself. But spend a couple hundred extra and have a complete kit shipped to you. So when you tear into dont have to worry about anything you missed finding it in a hurry to get your truck back together etc.....
vcassens
Godfrey,il
My thoughts exactly lol no to get the money together lol
Sent from my SPH-L900 using Tapatalk
rdnkbowhuntr
Louisiana
Call Jake at Irate Diesel. Great prices and customer service. Or nate over at unlimited diesel
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Coposrv
I haven't put together a fuel system for my trucks but I have for every mustang I have owned. My experience, it has always been cheaper to put it together on my own then to buy a kit ready to go.
