Fuel tank sump vs. draw straw
HobbyStock62
Mpls, MN
HeavyAssault
Middle, VA
I got mine sumped with a TSD tank sump. I was able to have the skid plate modded to extend the skid below the sump. Looks great and works well for me. I don't know if TSD is still making the tank sump.
ford rules
^All the reaserch ive done says -6 is fine, -8 seams overkill especially since it drops down to less then 3/8 to run back into the factory return on the sender.
HobbyStock62
Mpls, MN
so i can run -6 to the return from the factory sender, that wont be to small? i would ideally like to still use the factory sender, just drill out the hole for the 5/8 draw straw.
