fuellab wiring
JDub
Hooper, Utah
I used the Strictly harness to wire the Fuellab pump on my 99' 7.3L, made for a super easy and clean install.
06_Whitebull
Kansas
Truely a quality piece. Sure you can get them for less, but they probably won't last and aren't vehicle specific.
kyle43335
does it have the speed control wire for the fuel labs?
didnt see it in the link...
strokin6L
Springville NY
i built my own harness for my fuelab pump because at the time, Dennis didn't have these. Looks like a good thing to have if you get a pump
Strictly Diesel
Phoenix
No, it doesn't have the speed control wire. Most people are jumpering the pump to run at reduced speed and leaving it that way. I feed 400s in my race truck at reduced speed with no pressure drop.
Pizza pig
MD
all you need is a 4 inch piece of wire with a ring terminal connector on each end, jumping the ground and the speed control post on the pump. Its super easy.
java
Texas
Got mine on Monday, havent had time to install it but looks like a very quality piece!
kyle43335
i know. i built the harness in my blue truck.
i didnt know if dennis put provisions in the harness to switch pump speeds.
JDub
Hooper, Utah
Ran mine at half speed as well, 938hp on the dyno fuel pressure gauge never moved.
strokin6L
Springville NY
actually if you get the pump from Dennis...he already has it setup at reduced speed by adding the jumper wire. I'm sure you can just tap into the wire by using a switch so that if you want to run it at full speed....just flip the switch and there ya go.
Strictly Diesel
Phoenix
I haven't done that in a while. The original pumps required a special resistor and didn't have the external speed control lug so I did the speed control stuff here. Now they just require a simple jumper wire so we leave it to the customer to do.
huhner5
SW MN
Might be a little off topic,,, but Would this work with the AD2 at all??? looks similar?? Or does anybody know if some one is making an upgraded harness for that pump
Strictly Diesel
Phoenix
Not sure why it wouldn't, but if the harness problem is related to all of the ADII electric motors that have gotten diesel fuel in them due to shaft seal problems, my harness won't "fix" the problem. If the amp draw of the motor goes way up due to fuel in the motor (where it isn't supposed to be), it could still possibly damage my harness.
Blowby
Nice piece of wiring for sure. I set up speed control on a WOT switch so it only goes ape $h!t when I do.
