glow plug or relay replacement?
f350psd96
NJ
I have a 96 psd. Cold mornings when its not plugged in takes a lot of priming to get it running. Im not sure if i should replace the relay or glow plugs or both. any suggestions? thanks
POWER-STRUCK
Indiana
priming? no priming necessary on a powerstroke. do you have an ohm meter? or atleast a test light and we can walk you thru the diag
f350psd96
NJ
sorry i meant cycle not prime. im purchasing an ohm meter tomorrow. any advice would be greatly appreciated
Bugman
Gypsum, Co
First if you have never used a volt/ohm meter read the instructions, also you want a digital volt/ohm meter...
Then to test the relay put the meter on DC and with one side to a battery ground check the post on the relay. With the key off you should see battery voltage to just one large post of the relay. Now turn the key on. Now you should see battery voltage to the same large post and the other large post. There should be less than 0.3 volts difference between the two of them. So if you read 11.9 volts on one the other should read less than 11.6. If it is less then replace the relay.
To test the plugs you will find two plugs on each valve cover gasket. On each plug there are 4 pins, the glow plugs operate on the outside pins of each connector. Set the meter on ohms and zero the meter. With one side to a battery ground check each outside pin and write down the measurement that you get for reference. The plugs should be between 0.6 and 2 ohms, anything outside these measurements one way or the other is considered a bad plug.
POWER-STRUCK
Indiana
good write up Bugman! you saved me alot of typing. I guess i just need to post a good video up on my website teaching how to do basic tests like this
f350psd96
NJ
Sorry it's taken me so long to reply. Thanks for all the help. Turns out I needed a new battery and I need a new glow plug relay too.
f350psd96
NJ
yea one of the next things im buying. im only 17 and money doesnt come that easy for me haha but luckily a buddy of mine is an electrician and he let me borrow his. thanks again for the help!
mandkole
Northwest
Good suggestion on the HF multitester... HF stuff is fine for the casual user. Its not sexy or cool, but if money's short, Id definitely be investing in troubleshooting tools before mods for an old PSD.
f350psd96, if you can pull together $300, id get a scangauge also. You can do a lot with it and learn a lot about your motor's operation.
