glow plug question.
littleredstroker
where the antelope play
is there a way to test the glow plugs without pulling them out? and if they need replaced is there a brand i should go with? or are they all kinda the same.. ive heard stories of plugs falling apart and going through the turbine wheel and dont really want to do that just to save some $.
JDub
Hooper, Utah
You can disconnect the valve cover harness and test them at the connector without ever pulling the valve covers. The glow plug wires are the two outer most wires on each end of the connector. And we prefer using only Bosch or Motorcraft plugs. Seen problems with the cheaper Autolite and alike plugs, tips swelling and breaking, threading issues, etc...
SDS97_7.3
Finksburg, Maryland
Here you go.
The ohms value for any given pin (plug) should be between (.1) and ( 6) ohms. If you are getting a higher or open line (OL) reading you may have a bad glow plug. With higher values than 6 ohms or OL values you definitely have concern for opening up the valve cover/s and investigating further. Remember if you are testing the engine hot you will get a slightly higher resistance reading than you will when the engine is warm.
4cstr
aberdeen, sd
Here is a very simple method to determine if there is even power getting to them. When its darker outside, open your door so the dome light is on. Key on the truck. If the dome light dims...power is getting to them. And trust me...the dimming will be noticeable. Granted this method doesn't tell you WHICH glowplug is going bad, but it does let you know if power is getting through the relay to the glowplugs.
