Got Glowshifts?
DEEZUZ
NO PUKESTERS
NWI
I highly suggest the GS Delete mod... And put these in place...
I always thought it was odd that with the 203* that I never saw anything above 190*. Upon first test drive with the Isspro I saw my temp get as high as 209*(56* ambient today)
Now I wonder how high my temps got when I really worked the truck.... Ugh
Im also wondering if my egts climbing to over 900° when accelerating normally to 65mph isnt a vatometer issue. Truck runs great, makes 30psi with billet wheeled 38r, stealth oil, and full fuel system and stock injectors. Before with stock injectors, stock oil, and standard 38r the truck would be under 700° at that speed even accelerating.
Those gauges look nice!
DEEZUZ
NO PUKESTERS
NWI
I didn't have to question the pyro meter, I knew there was an issue when my egts would be 0 one minute than 1600 the next......
ghohouston
Lewisville,Texas
My glow****s did the same thing with the egt's, then came the fuel pressure, but boost always seemed normal. Of course when I replaced my fuel pump, and then tried to use the old one to syphon diesel from a container, and it wouldnt even pull fuel, I couldn't believe my truck even ran with it, much less pushed 238/100's and still read good pressure. I felt bad for my injectors. The only thing I actually liked about my glow****s was how much they matched the factory gauges, and color selection.
DEEZUZ
NO PUKESTERS
NWI
I will admit the glowshift is the Exact same color as factory. Isspro is a shade or two off... That was the only reason I got Glowshifts was cause they matched.
DEEZUZ
NO PUKESTERS
NWI
I ain't doing a damn thing for at least another 6 months.... It took everything I had to get the ambition to get these done.. Lol
backwoodsboy
Merica
Not sure how I feel about this...
07powerstroke91
This is probably the biggest reason I still have glowshifts...I absolutely HATE wiring, and on top of that ripping all your panels off to hide the wires and try to make it look clean, yeah I'm getting a headache just thinking about it lol
CSIPSD
Bend, OR
Ripping panels off?
WTF are you guys doing to install gauges? Remove the A-pillar, remove the one cover below and your good to go...
Funny.
DEEZUZ
NO PUKESTERS
NWI
Lol, yea that's not an issue. Its just being at work to do it.. Hate dragging tools home
ghohouston
Lewisville,Texas
to clarify for you, i ran them about a month tops that way before i installed the new fuel pump i had laying around. believe me, if i would have known the condition of that pump, i wouldnt have even ran the stock injectors on it. and didnt you send them to rosewood after you bought them? if i would have thought for a second there was something at all wrong with them, i would have told you. my truck ran fine with them, without a glitch the whole time
07powerstroke91
Ripping panels off?
Funny.
And the grab handle...and the trim/moulding...and then the trim on the kick panel so you can pull up the carpet and put the wire out to the sending unit under the hood...its a pain in the ass don't act like its not
CSIPSD
Bend, OR
Where and the hell are you running wires that your pulling carpet up??? LOL
And the kick panel? Have you ever run wires before?
Hate to see what you would do if you needed to add a plug in someones house...
"Yup, remove all the sheetrock on that wall so we can fish that wire from the attic...":doh:
backwoodsboy
Merica
I was just flipping you crap man.
I'm convinced those injectors were cursed anyways. I had them in my truck for less than a month and ran into money troubles so I sold them. They disappeared from a USPS shipping terminal on the way there and have never been seen from again.
