juniort444e
I just bought and replaced my blown up pmr motor with a 95 forged van bus motor. I swapped EVERYTHING over and now im having some issues.
First off it takes awhile to start.
While its running the speedo is jumping around when put in gear but not moving.
When i turn lights on the driver side side marker comes on but not passenger side.
The instrument cluster works but the right turn signal stays lit and the turn signals dont work.
Need help with this. I put the grounds back on the motor but will take them back off to and srub them clean to rule that out. And the ground is on the back of the motor as well. Im also hoping some of my starting issues are from the icp?? ( sensor on oil rail) is broken and nit plugged in.
sent from uranus
sent from uranus
