I ordered the wrong IC piping replacement kit and got the one that requires reusing the OEM boot by cutting the clamp that secures it to the OEM pipe.
The instructions state to be careful not to nick the rubber - yes, I get that ...
Those who have successfully cut the clamp, any advice so that I avoid cutting into the rubber? I will be using a dremel with a cut off wheel.
Thanks
Thanks
