factorydefect
ok my truck started to overheat and it popped the radiator. well after changing it and the water pump and theremostat it still kept puking coolant.it didnt do it all the time . if i let the truck sit at idle for 30 min it did nothing.if i drove it a 1/4 of a mile with decent accelartion it would puke. i pulled out my injectors and it looks like 3 of them weren't seated properly.the bottom of the cups has black on the inside of them where the copper crush washer goes.the bolts on the injectors wasn't very tight . i was using a 1/4 drive small ratchet to remove the bolts and i barley had to give any effort to remove them.does my coolant problem sound like unseated injectors and also whats the chance that the cups are loose and how do i test that.
