Heat not working properly
6
6.4stroke
Guest
My heater doesn't seem to be working that good in this cold. Here in pa it's Been around 0 degrees. I let my truck idle for 15 minutes. Heat was working ok. I drive 10 minutes and its blowing cold air. Pulled over coolant level is fine. So then a played with the settings and got it to blow decent. Since then it's not been blowing as hot as it should. I have it set on 90 and like I said it not blowing as hot as it should. I don't think I have a blown hg. No oil in the coolant no abnormal white smoke. Truck runs good. Any help appreciated
Powerstrokeracing
Pressure test your cooling system just in case. And go for a drive and see if heat kicks in when your at WOT.
When you switch temps does it act like the blend door is moving? Like can you notice a change a temp at all?
gman1
Michigan
Are you running a cold front on your truck? If not they help out allot on these trucks when its that cold.
RedRice589
Ocala, Florida
Does your truck get to operating temp correctly my thermostats were makin mine do that to me. Supposed to be 190-200 it wouldn't get above 160
6
6.4stroke
Guest
Yea. Right at the moment it's working great. Went from 90 to 60 on climate control. I felt colder air immediately went back up to 90 hot air. Lets see if it acts up again
DEEZUZ
NO PUKESTERS
NWI
do you get heat while driving/revving, than ice cold while idling?
6
6.4stroke
Guest
found out that everytime i run wot throttle my heat goes away for mayb 30 sec. then comes back on. oil and coolant temp are 3 degrees difference coolant level is fine.
907DAVE
AK
My bet......head gaskets are on their way out. Get a chemical test done before spending ANY money on replacement parts.
6
6.4stroke
Guest
when I do a presssure test what should the pressure be under wot if my hgs aint blown
