Got a code for a reductant heater assembly bad. The part is on National back order with no time frame as to when it will be back in stock. Truck is a 2012 with only 19k miles. This is my daily driver/ work truck and it's BS I don't know when I will get it back. Truck is all stock. They say I can't pick truck up as it may shut down unexpectedly.
Should I wait on Ford to fix it?
Or should I delete all the BS right now and go get my truck? What is needed to do this the right way?
It also went in for a rear pinion seal leak. Truck is like new, really pisses me off I can't even use it.
