Help....Im broken and need advice
high desert stroke
Trailer Park
Literally...I broke my leg over Thanksgiving riding my dirt bike. Now my 99.5 PSD F250 is pissing fuel out of the front of the motor and I'm unable to crawl up there to work on it. From what I can see it looks like its coming out of some tube on the passenger side. My brother in law is coming over to help but hes damn near retarded when it comes to anything mechanical. Any body ever had fuel leak like this? any help is appreciated:fordoval:
Dmstrucks02
Pearland, TX
That tube sounds like the fuel bowl drain line. Look at the back of the fuel bowl and see if the valve is open
Got tree'd big time
Justin@DP-Tuner
Did you drain the fuel bowl recently? As stated above, check the drain valve on the back of the fuel bowl.
Dmstrucks02
Pearland, TX
high desert stroke
Trailer Park
Ok, my BIL climbed up there and says the lever is in the closed position. Its definitely that tube its leaking from. He opened and closed it a few times. Hopefully it was just a piece of something holding it open and leaking past
Justin@DP-Tuner
The o-rings are prone to leak on that valve.
You have never drained the bowl when changing fuel filters?
