HELP! Looking for a front stub shaft for 2008 f-250
superdutyfarmer
Tamaqua, PA
So I tried pulling last night and ended up not making it 3 ft before the front left u-joint let loose and ended up taking out the stub shaft u-joint. Lots of cool pieces on the track. I am trying to put it back together asap. Anybody with any leads on a used unit please hit me up. Rodney (570-778-5189)
powr2stroke
Tennessee
Ordered mine from Sunrise on here , not many of those just laying around . Might look at your lockout also . Mine grenaded .
superdutyfarmer
Tamaqua, PA
lockout looks ok, I have it pulled apart. It looks like the bearing inside the hub the u-joint, balljoints, and stub shaft are all I'll need. along with a dust shield and vacuum seal. I am finding kits on ebay for 200-210. I am going to check with the salvage yard close by work tomorrow after work. They had one for another guy here who used to pull previously
NotStock
Tucson, AZ
I have a complete passenger side including the inner axle and lockout I believe. Shoot me a call at (520)465-7971
powr2stroke
Tennessee
Good luck man , I couldn't find anything when mine let go .
On edit : looks like Trevor might have ya covered
superdutyfarmer
Tamaqua, PA
Trevor I'm going to run to the place just down the street from work that is a big salvage yard. If they don't have anything I'll give ya a call. I don't have a real Idea what a used unit would go for. I also need the driver's side, It would look kinda funny with a long axle like that hanging out the left wheel haha
NotStock
Tucson, AZ
Is your inner shaft damaged? If you dont need that inner axle, just the stub on out, I can press the ujoint out and send everything else. Either way, its there if you need it. Whatever is reasonable on price. I can get it shipped same day via whatever service you want.
kyle43335
I just did the drivers side on a friends 08. Believe it or not,the stub shaft was cheap from ford. Couldnt believe it.
superdutyfarmer
Tamaqua, PA
Well after calling around and seeing pricing and availability, Trevor was the man who helped me out. Thanks again for the fast response and good parts. Possibly going to try it again here on Sept 1st to see if a lower gear will keep it together.
NotStock
Tucson, AZ
No problem man! Glad it was of help to you! Good luck with getting her to hold together this time!
superdutyfarmer
Tamaqua, PA
Got to find some smaller, less agressive tires, I think that is key to keeping the wheelspeed and rpm but allowing the dirvetrain to live. these 35in Stts don't give much at all on a clay track haha
