help please! no electrical power at all
RRmachinist
well to start off with i owned this truck for three months. it blew a head gasket last month and started pecking, so i tear into it and replace the gaskets put in arp studs anda new valve train, with the cab on what a PITA. anyway last night i get it all back together and when i was putting the batterys in i accidentally grounded the drivers side positive cable on the engine now i dont have any power to anything. there is power at the cable that bolts to the firewall. dont really know where to go from there any help would be greatly appreciated thanks
RRmachinist
Are there any fusible links inside the cab, or a main fuse. I dont have any power coming in to the fuse Box in the cab
RRmachinist
ok i feel like a dumba** i found a wire tucked down beside my batt. i hooked it up and i have power now but no crank and no fuel pump,the security light is flashing and showing all kinds of faults on the desplay screen. do you have to reset the computer after having all that out or is there some thing else wrong
Dzchey21
wyoming
Check the ground under the cab on the right side.
Check all three plugs for the cab harness under the master cylinder they have to be connected all the way
78f100
Bonifay FL
Try unplugging the small round plug on the pass side and touching it to the battery. It should spin the motor over, then plug it back in should crank with the key then. My brothers truck and mine have done that after having the batteries out for a while. Not sure why but it will reset whatever is locking it out, for us anyway.
RRmachinist
Thanks for all the help I finally got it there was a power wire off on the drivers side. I guess thats what I get for working on it with two hours sleep I two days.
