Is it a '13 you just got? If so, deletes are 'not allowed' (EPA BS), however having said that, there's a couple guys who have done just that.
One posted here that he did. When he got flamed he posted pics and a video of his '13 deleted as proof.
Getting a Race Tuner instead of the Street Tuner seems to be half the battle. Seems like I saw CFD posting somewhere that they had them in stock.
Personally I like the aFe 5". It's a true 5" stainless from the downpipe back and leaves a lot of room around the rear shock which was a problem with the MBRP cat back I had on originally. Also, I got the one w/ muffler, it's quiet and doesn't drone until you stomp on it, then it roars.
EGR you can do just the block plates or the full delete. Not sure there's a big advantage with the full delete other than your truck will weigh 50lbs less and it's easier to work on w/o all that stuff in the way. H&S is unpainted steel so it'll rust and the Sinister is machined aluminum. Wish I'd done the Sinister.
If I can find the post w/ the deleted '13 I'll link it for you, but a search should find it pretty easily (if it's not over at powerstroke.org which it may be.)
**Edit Here's the link to the deleted '13 on the .org
http://www.powerstroke.org/forum/6-...391569-2013-completely-deleted-6-7-video.html
