help with a fitting for fuel system!!!!
what a mess
rockford il
i have a banjo bolt that connects to my fuel filter housing on the motar and i need a fitting to fit in it so i can connect my fuel system up and i cant find what i need who was one or what size it is ? its an 05 if that helps its the main supply line that i need to get the fitting for so i can finish setting up my new system thank you much
05wh250
hendersonville, nc
Probably cantact jj at dozers diesel. But for mine i used a compression fitting on that line where it hooks to the line from the stock pump behind the air filter assembly.
faster6.0
spindrift I believe he is referring to the largest banjo bolt that feeds the fuel filter housing. if this is correct watamess, you would ask your local fitting store for a 14mm x 1.5 thread pitch boss O-ring style fitting in a 90 to your hose from your fuel pump. I have plenty in stock if you cant find them locally.
