The other night my truck ran great!! The next morning I get into my truck and crank it. I let it idle then I pull out of my driveway and it starts spitting and sputtering like its starving for fuel. Since then the truck will not crank. And has had no prior issues with the truck. Did pull a few codes from it and can't make heads or tails of what's actually going on with it. Codes are p008c , p179a , p0000, u0253. And this morning I got a p0291
The truck is also a job 2 truck and has been ******d now would I be wrong to check the fpr sensor or gas pedal in this situation
