HELP!
kevin
springdale wa
OK I have compounds 205s tuned yadda yadda yadda.. when I go to the track with it it will go to 100 mph and the instrument cluster resets and the truck dufuels.. DISCUSS
2wd-fire
Their a setting in my sct that removes the top speed limiter? Idn if that's your problem
harrisford
Kinda sounds like the same thing my truck does when I hit the governor and turn the key forward. 100 mph is 160km/h so that sounds like you're hitting the limiter
TooMuch03
West Bend, WI
Whose tuning? I know the files I get from Matt still have a top speed limiter, and I have to select to remove the limiter in the adjust options section. If you have done that, then I have no idea. Hope you get it figured out.
