HELP
Sooter6.7
Eastern WA
Okay guys so I have this noise every time I accelerate. It's a very high screech and it almost sounds like it's the turbo when I pop the hood. Any suggestions?
Dieselwrench
Oklahoma
Check for any loose clamps on any of the rubber boots connecting the pipes together from the turbo to the charge air cooler and back to the intake. If you don't find any thing there pull the intake boot off the turbo and check for any excessive play in the shaft. The impeller should not be able to contact the outer housing at all. It's probably either a loose clamp or possibly a gasket leaking in the intake somewhere.
Sooter6.7
Eastern WA
Okay I'll pull it off tonight and take a look at things. I still have the power and boost pressure all seems normal.
Sooter6.7
Eastern WA
No codes. Just a noise when I get over 1800rpm, idiling I don't hear it or normal driving just accelerating past 2000 getting on it
Sooter6.7
Eastern WA
No I did not find anything, nothing loose and everything is air tight. Thinking about bringing it down to the shop it might be a gasket.
Jacob @ No Limit
Indiana
Might be your metal gasket for the exhaust side of egr block off. Those tend to leak on any engine if not torqued properly and clean. Just a thought.
Raptorgabe
i did my egr and made that go awefull screech it was the metal gasket on the egr blockoff plate
