Usually there is no separate high beam, They use a shutter system on the bulb. The shutter wiring can be a bitch to install correctly and safely.
On the kit I got, the vendor said to install the shutter wiring in the groove that cuts through the threads where the nut for the projector went. No clearance, the nut would have cut through the wiring. If I had modified the depth of the groove than the warranty would have been voided. Said I didn't know what I was talking about. They didn't give refunds only credits. So, gave credit away to someone with a SD truck instead. $240 down the drain.
Have fun....
uke:
