Hot shot diesel treatments.
jdeeg4276
Vancouver wa
Any opinions on there products?
Customer is taking his truck home cause he is going to use this hot shot products to fix his bad injectors on a 2000 7.3l
Its a oil/fuel treatment that fixes stuck injectors. I say no way if the injectors are already bad. But a good injection cleaning method if truck is already running with good injectors.
strokin6L
Springville NY
i would use rev-x or AR9100 before i tried the hot shot stuff. The rev-x and AR9100 have already fix injector stiction issues for most guys...this stuff works. However, if there is something mechanically wrong with the injector...the rev-x and AR9100 wont fix that. If it were me....i'd try the rev-x or AR9100 first and see what happens.
Vizsla
Hot Shots worked really good for me, made an immediate improvement(Elite 185s). You can pick it up at Tractor Supply in a pinch.
Ross@Flyindiesel
Kerrville, Tx
hot shot takes awhile to work if it does. rev-x on the other hand if you cant notice a difference within 2 start ups then you got a problem with the injector and no additive will fix it
